Does the phone charge when plugged in to USB?
This is a discussion on Does the phone charge when plugged in to USB? within the Nexus One forums, part of the Google Phones category; If you've ever used an iPhone, you know that that's an alternative way to charge the phone, aside from the A/c adapter. What about the ...
Results 1 to 10 of 18
Thread: Does the phone charge when plugged in to USB?
    Junior Member jakeqT's Avatar
    If you've ever used an iPhone, you know that that's an alternative way to charge the phone, aside from the A/c adapter. What about the Nexus One? Does it charge when connected to your PC/Mac?
    TIA,
    jake
    Senior Member thomaslkuo's Avatar
    Quote Originally Posted by jakeqT View Post
    TIA,
    jake
    You make it sound as if Apple invented the whole charge from a USB connected to the computer. lol.
    Yes, N1 can be charged connected to the computer via USB. But not as fast as via a/c adapter.
    Didn't mean it to sound that way, but thanks for the reply!
    Member DiEg0's Avatar
    USB charging is slower than using adapter.
    Member davidlm's Avatar
    Quote Originally Posted by DiEg0 View Post
    Echo echo echo ....
    Quote Originally Posted by davidlm View Post
    Echo echo echo ....
    . ......cho...ho....oo...
    Junior Member hatim_lotfey's Avatar
    Charge control
    That's great. Is there a way for the device to control whether i want it to charge or not while connected via USB? I heard that some other devices has this capability.
    Senior Member ardynine's Avatar
    I don't think so. Not sure why you would want that anyway.
    Well i'm not sure if a fully charged battery will make the device to be running powered directly by the still-connected usb cable. I mean to override battery power consumption. You know, like a laptop that is fully charged and running directly from the charger power.
    Junior Member Matchbook's Avatar
    I just got my Nexus One!
    Do I have to charge it completely before using it for the first time?
  1. First Look at Sony Ericsson Xperia Arc
    Last Post: 01-17-2011, 05:23 PM
does android phone charge usb
