Help!
This is a discussion on Help! within the Nexus One forums, part of the Google Phones category; I used this thread: http://www.nexusoneforum.net/forum/n...html#post23468 to get 3G on my nexus, but now, even with wifi up, its still connected, its sucked up all my ...
Thread: Help!
    UK
    8 times
    Nd1razor
    Help!
    I used this thread:
    to get 3G on my nexus, but now, even with wifi up, its still connected, its sucked up all my credit, and send me a msg saying i need to topup to use internet, how the hell do i turn it off without deleting the APN?
    cxm
    cxm is offline
    Senior Member cxm's Avatar
    you can use apps from the market such as apndroid (free) to toggle mobile data on and off as you need to. I currently don't have a data contract so only use 3g from time to time - it works fine for me. I also installed netcounter (again free) count how much data was going over wifi and over 3g
    Quote Originally Posted by Fury View Post
    I used this thread:
    You can also set up a dummy APN account and activate that one... this way you don't have to delete the 'real' APN account or install any apps.
    UK
    8 times
    Nd1razor
    Cheers, i think i might go with bishop's option..
    thanks for the help, have about 57 msg from O2, very annoying...
    Least i can disable it now.
    Senior Member Rusty's Avatar
    APNDroid rules for this, I also use Data Counter Widget to see how much I've used.
    UK
    8 times
    Nd1razor
    Ill take a look at them, cheers
