Sleep/LockScreen delay before lock code required
This is a discussion on Sleep/LockScreen delay before lock code required within the Nexus One forums, part of the Google Phones category; I hope I'm describing this properly. I know how to change the settings for how long the screen times out and goes to the lockscreen ...
Thread: Sleep/LockScreen delay before lock code required
    Junior Member DistortedLoop's Avatar
    I know how to change the settings for how long the screen times out and goes to the lockscreen on wake.
    What I'd like to do is have the lockscreen NOT require the lockcode for a couple of minutes after first going to sleep. iPhones have this setting, and it's pretty handy in my opinon.
    Basically, you set the phone to not require the lockscreen pattern for a minute or two after going to sleep.
    I haven't found a setting for this. Anyone know of a third party app that might do this?
    There isn't a setting for what you describe AFAIK. All you can do is extend the time for Screen Timeout:
    Home > Settings > Sound & Display > Screen Timeout
    Thanks, but like I said, I already know how to do that. That's not very battery-life friendly, sadly.
    Battery life on my Nexus One is atrocious, I won't do anything that makes it worse than it already is.
    It's a really handy feature on the iPhone for me - I use a gym logging application, and if I set it to a few minutes before the autolock engages, I can do a set, log it, turn off the screen to save battery, do a second set, and then turn on the screen to log the next set without having to enter the pin. Not a biggie, but convenient.
    Thanks again.
    Junior Member thiago's Avatar
    Search android market for AutoLock. It's not 100% accurate, but does the job most of the time. I suggest you give to it a try...
    Regards,
    Thiago Souza
    Senior Member Fuse's Avatar
    Quote Originally Posted by thiago View Post
    Regards,
    Thiago Souza
    I also suggest this...i use it with Locale and out does a good job
    Rooted Nexus One
    Quote Originally Posted by Fuse View Post
    Thank you both, I will check out AutoLock and Locale.
  1. Test
    By tapatalktest in forum Off-Topic Forum
    Last Post: 03-29-2011, 03:41 AM
android delay lockscreen
android lock screen sleep delay long time
android lockscreen sleep time
android screen lock password delay
android sleep tapi tidak mengunci
delay iphone pin required
delay surface lock screen
delay time to require pin android
how to delay iphone 6 locking
how to delay lockscreen on android
how to set iphone 6 for longer delay before locking
iphone 6 delay screen lock
lock screen after time delay in android
sleep lock screen delay
surface lock screen delay
