Will Nexus One work with AT & T Prepaid? I am having problem
This is a discussion on Will Nexus One work with AT & T Prepaid? I am having problem within the Nexus One forums, part of the Google Phones category; I got my Nexus One today. I am using AT & T prepaid 25 cent plan previously.Once I got the phone and I put my ...
Thread: Will Nexus One work with AT & T Prepaid? I am having problem
    Android Lurker venki5star's Avatar
    Unhappy Will Nexus One work with AT & T Prepaid? I am having problem
    I got my Nexus One today. I am using AT & T prepaid 25 cent plan previously.Once I got the phone and I put my prepaid card and tried it. I got no signal.
    And I tried with AT & T postpaid connections which is working fine.
    Am I missing something?
    I am using AT&T prepaid, and it works fine. You might check your phone particulars with the configuration utility. With the SIM card inserted you should have a phone number and signal strength. If you can't make a call, perhaps you need to provide funds. There's a web page for this, but you need your phone number to log in.
    Quote Originally Posted by davidalow44 View Post
    Are you tell about the AT & T recharge page? Or is there an web page for Activating AT & T sim in Nexus One?
    This prepaid sim is working with Nokia N90 8GB mobile.
    Got it fixed. ATT has locked the sim. I went to the store and got it fixed
  1. Confused about WiFi Calling
    Last Post: 05-10-2013, 03:00 PM
