N1 Problem
This is a discussion on N1 Problem within the Nexus One forums, part of the Google Phones category; hi all, I am using nexus one about 2 weeks in singapore. 1. Battery is very less time. even I changed full, it will come ...
Results 1 to 10 of 11
Thread: N1 Problem
    Junior Member ezhil.uk's Avatar
    N1 Problem
    hi all,
    1. Battery is very less time. even I changed full, it will come to 5 hours only
    2. when I charge the battery will becoeme hot like burning ( Just i put within 10 mins)
    3. when I use the phone about 10 min; same hot ; even in the screen and back side of the phone.
    lower bottom of back is very very hot.
    Pls advice.
    Senior Member cbroberts2010's Avatar
    That may be defective charger...I use the outlet charger at night and sometimes the USB during the day..It does not get hot just a little warm. I have heard of others having the same issue, so I am kinda paranoid and check it for overheating often. Search some more threads, because I believe a gentleman said he changed his charger to an old one he had from a previous phone and problem was solved. Sorry I couldnt be of more help to you.
    Hi,
    I am using the google charger only. for my case is not warm. it is hot like burning.
    How to contact Google regarding the battery issue
    Your best bet would be to contact HTC, as their support I believe is a little better than Google's.
    Junior Member DanielSon88's Avatar
    I always remove my silicone cover before charging.
    The phone does heat up a bit still but only gets really hot if I'm listening to music while its on the charger
    Thanks. I also remvoe the cover before charing. Still like burning.
    I went singapore HTC service centre. that is also bad. No proper response from them. they are telling this google brand and blabla.
    I thing this phone is suitable for Cold country.
    Member yao86's Avatar
    It's normal :)
    Wa Bro… relax man Bro… Lolx
    I’m also from Singapore Bro…
    Now a days Singapore too HOT already
    Got Hot Women, Hot XMM (Teens Girls), Hot Cars, Hot Chili Crabs, Hot Phones and More HOT staff!
    Same lar… My N1 get Hot Hot when use too long due to showing off to others…:rofl3:
    It's normal man... LOLx
    Everyone smartphone is hot when it's charged. Atleast thats the case with my Nexus One and Droid.
    Froyo 2.2 Stock
    RA-nexus-v1.7.0
    [SIGPIC][/SIGPIC]
    Bro,
    Atleast Hot is ok; But the battery dead within 3 hours; i am not using the much......
