Orange network settings help (MMS) - UK
This is a discussion on Orange network settings help (MMS) - UK within the Nexus One forums, part of the Google Phones category; Hey folks, first post here, but I've been floating around the past week or so. I have a Nexus one and I'm from the UK. ...
Thread: Orange network settings help (MMS) - UK
    Junior Member Monkeyspaz5000's Avatar
    I have a Nexus one and I'm from the UK. I am on Orange contract.
    Curious about the settings etc I should have in my phone as I can't seem to send/receive mms!
    Under APNs I have two set up...
    1 for Orange internet access
    APN : orangeinternet
    username : (blank)
    password : (blank)
    MCC : 234
    MNC : 33
    The internet settings as far as I can tell work fine.
    Now the MMS :
    APN : orangemms
    Username : Orange
    password : password
    MMSC : mms.orange.co.uk
    MMS proxy : 192.168.224:8080
    MCC : 234
    MNC : 33
    Is there something I've done wrong with the above? Should I have two APNs set up, or do you have all settings under one? Also, are the above settings correct?
    Any help appreciated as it's now driving me mad!
    For your mms settings try...
    APN: orangemms
    Password: mulitmedia
    Proxy: 192.168.224.10
    Port: 8080
    MMSC: http://mms.orange.co.uk
    BTW. No you do not need two APN settings.
configuring orange network on android phone
set up orange mms nexus
