Problem saving contacts :(
This is a discussion on Problem saving contacts :( within the Nexus One forums, part of the Google Phones category; tried the battery thing. no go. heres something i noticed. i save the contact, and it shows in my contacts. as soon as i lock ...
Results 11 to 20 of 30
Thread: Problem saving contacts :(
    Member Lokesh_nexusone's Avatar
    heres something i noticed. i save the contact, and it shows in my contacts. as soon as i lock the phone and unlock, its gone
    ok i just switched off the sync for contacts alone. now that its not syncing, it seems that all my new contacts that i add where theres no internet are actually staying... but now i cant sync them... how awesome
    Junior Member club968's Avatar
    I have this EXACT same problem.....didn't know it was related to connection issues until I read this and tested it out. Doesn't make sense, frustrating really.
    Quote Originally Posted by club968 View Post
    tell me about it... so right now its either
    Sync contacts, but only add new contacts when ur online (which is unacceptable to me)
    Dont sync contacts, but add contacts whenever (which is what I used to do with my old phones anyway that didnt sync any contacts)
    so yeah i have to choose the second option... as of right now, I cant have the best of both worlds like i should... which blows...
    Junior Member wazza11's Avatar
    this worked for me
    contacts - Display options - choose your google account and I ticked the one that is blank, just above 'all other contacts'. Then they will show up along with your google contacts.
    Quote Originally Posted by wazza11 View Post
    ive tried them all, and none of them seem to work for me...
    On another note, heres how I am syncing as well as adding contacts without an internet connection... its a little more manual than it should be, but itll do for now.
    I just turn off sync for contacts. I then go about my life adding contacts just like on all other cell phones (I know... surprising). And then when im at home with my wifi network bored, I go to the sync, enable the contacts sync. As soon as I enable it, it does a quick sync. This adds all the new contacts to Google Contacts. Then immediately turn off sync again. Go about your life. Repeat when necessary.
    Senior Member ardynine's Avatar
    you should really report this as a bug on the google android forums.
    I'm Having a Problem - Android Help
    if you don't want to deal with it, i can report it for you.
    been there, done that... they dont seem to care...
    My contacts do not add - Android Help
    i dont think i have this problem, however i have a diff one. when i go into the msg app and want to create a new text and type "alex" for example in the "To" field nothing comes up. And i have an Alexander in my contacts. I have many contacts like that which im guessing are saved a different way and never show up in the message app. Kinda annoying
    nm i figured it out you have to save the contacs under "mobile"
contact savong problem on htc one
contacts wont save on evo 4g
htc evo 4g can't save contacts
htc evo 4g not saving contacts
htc evo 4g wont save contacts
htc evo phone contacts wont save
htc evo won't save contacts
htc evo wont save contacts
i m sabing contact on htc one but it does not shown on liist why
my evo wont save contacts
my htc evo 4g wont save contacts
my htc evo wont save contacts
my htc evo wont save numbers in my contacts
nexus 4g not saving contacts
why is android contacts to display not saving
