Problem saving contacts :(
This is a discussion on Problem saving contacts :( within the Nexus One forums, part of the Google Phones category; Originally Posted by d1mitrov nm i figured it out you have to save the contacs under "mobile" how do you choose how u save the ...
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Problem saving contacts :(
  1. #21
    Member Lokesh_nexusone's Avatar
    Quote Originally Posted by d1mitrov View Post
    how do you choose how u save the contact?
  2. #22
    when you go to contacts, menu, add new contact, and the screen comes up to enter their info there is a tab next to where u enter the phone number and you have to tell it wether its a work, mobile, business, other etc. as well as other options.
  3. #23
    Junior Member singlegoldbangle's Avatar
    those options mean that youre assigning the number as a home number or work number or whaterver.
  4. #24
    Question & Suggestion....
    The contacts that you've entered and have disappeared, if you do a search on your contacts tag does it show?
    If yes, go to your Contacts tab > display options > touch your account > check all boxes 'under' your gmail account > press done and check again.
    had the same problem and thankfully i went to page one lol problem solved cheers bishop
  5. #25
    UK
    8 times
    Nd1razor
    ill give bishops settings a shot
  6. #26
    Junior Member Gvisgr8's Avatar
    Bishop6 settings works..
    Restarted phone -> selected all ticks under contacts accounts...
    and done...able to see already saved(not visible) contacts and now able to save contacts also , without loosing them again..
  7. #27
    Junior Member nexus46's Avatar
    On your Contacts tab, Menu > display options > touch your primary account...
    Make sure as well as 'System Groups: My Contacts' is checked, also see if 'All Other Contacts' is checked.
    If not; enable and see if that fixes your issue.
    this work solved the same pb for me; it is weird they made it so complicated.
  8. #28
    I think this problem has now been addressed with Froyo. It seems to be all OK with Froyo.
  9. #29
    Junior Member ibdat88's Avatar
    Quote Originally Posted by Lokesh View Post
    I'm using froyo and never had the problem before..actually just started experiencing this problem today
  10. #30
    Junior Member Cynar's Avatar
    Talking Solved
    I ran into the same problem. None of the methods listed so far worked. Finally found the cause though.
    I changed from googlemail to gmail. While everything else seemed to work with it, contact sync only works one way. You need to create a new google account sync on the phone with the correct address.
    Not sure how to delete the old one yet. When i go to it threatens to reset the phone to factory defaults. :S
contact savong problem on htc one
contacts wont save on evo 4g
htc evo 4g can't save contacts
htc evo 4g not saving contacts
htc evo 4g wont save contacts
htc evo phone contacts wont save
htc evo won't save contacts
htc evo wont save contacts
i m sabing contact on htc one but it does not shown on liist why
my evo wont save contacts
my htc evo 4g wont save contacts
my htc evo wont save contacts
my htc evo wont save numbers in my contacts
nexus 4g not saving contacts
why is android contacts to display not saving
