Battery life observations..
This is a discussion on Battery life observations.. within the Nexus S forums, part of the Google Phones category; Unless thay come up with a longer lasting battery this phone is pretty much usless as it is. I took mine off charge at 4pm ...
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 52
Thread: Battery life observations..
  1. #41
    Junior Member ziggy12345's Avatar
    Unless thay come up with a longer lasting battery this phone is pretty much usless as it is. I took mine off charge at 4pm and it was dead by 11pm.
    Doesnt Samsung read the forums??
    Jeez
  2. #42
    Junior Member kawadiver's Avatar
    In fact, i switched off the 3G radio, i.e. enabled the 2G only option, and this saves a great deal of battery, and it is way enough speed to sync all account and run all notification updates.
    And yes, i switch it back on when i want to download/upload pics, but generally it is also enough to read web news (using Dolphin and their Ad bloker plugin).
  3. #43
    Switching the phone off altogether will save a huge amount of battery life. Taking the phone back to the shop will save me 450 quid as well..lol
  4. #44
    Junior Member Discosis's Avatar
    Quote Originally Posted by ziggy12345 View Post
    Jeez
    I'm telling you, it's the live wallpaper*. Switch it off, make do with a static backdrop.
    (* If you've already done it, then in fact, its not the live wallpaper and you likely have a defective battery and/or phone...)
  5. #45
    Yup, turned it off. I have come to realise a smart phone needs a smart operator. Maybe I should have stuck with my stupid phone....lol
  6. #46
    Member yao86's Avatar
    It also partly depends on your area signal
    Like for an example:
    When Im at Town or anywhere common area in Singapore, my Carrier Singtel Signal is Strong and my Nexus S can last me more than the whole day (>12hours) of normal use (Calls, Message, E-mails, play around etc)
    But when Im at my work place at Kranji area of the ending part of Singapore near Malaysia (Google it) My Nexus S 100% fully charge and after 2hrs, it drops to lass than 80% without using it!
  7. #47
    LOL... I took the phone out of pf the leather case I purchsed and the phone lasts 3 times longer now. The case was pushing on the side button and the screen was on almost all the time.
    Like I said.. smart phone, stupid operator...lol
  8. #48
    When you buy a smart phone you need to complement it with a stupid one
  9. #49
    Senior Member Zehlek's Avatar
    With my nexus s, battery would 10% within 20 minutes. I decided to try a regular wallpaper instead of live and I have been on 92% for the last 4 hours so it was my live wallpaper causing mine
    Sent from my Nexus S using Tapatalk
  10. #50
    Yeah it all these fantastic features you cant use. A bit like sitting in a ferrari in a trafic jam. About as much use as a chocolate fire guard
battery nexus 7 screen 70%
my android is full charged but showing only 67% battery
nexus 4 adjust power use
nexus 4 adjust power use wifi
observation on battery life
observation which battery stay longest
observations on (which battery last longest)
sample an observation on which battery last longer an
