Nexus S Only edge access No 3G
This is a discussion on Nexus S Only edge access No 3G within the Nexus S forums, part of the Google Phones category; Actually, the AT&T UMTS bands 850/1900 are very commonly used in the Americas. The T-Mobile 1700 band is less commonly found outside of the USA. ...
Results 11 to 15 of 15
Thread: Nexus S Only edge access No 3G
    Things are going to get even more complicated as new spectrum blocks are used in the USA and elsewhere.
    Junior Member alank's Avatar
    Quote Originally Posted by davidalow44 View Post
    I wasn't comparing AT&T's 1900 band to T-Mobile's 1700 band, I was comparing it with the 2100 band that the Nexus S supports. 2100 is much more commonly used in the world than AT&T's 1900.
    Junior Member spacemanspiff33's Avatar
    Hate to be the one to break it to you, but there is life outside the USA. The rest of the world usually (not always, but definitely more common) the 2100mhz freq for 3g. I'm currently in Hong Kong rocking 3g over 2100mhz on Smarttone/Vodafone with my Nexus S.
    Its not a restriction, or a lock, its simple compatibility issues. The reason google didnt include support for every frequency under the sun, is because that would simply add to the cost, and since AT&T couldn't give a damn about the Nexus, why should their frequencies be supported in the initial release?
    Give it time, I'm sure they will release a Nexus S with support for 850mhz 3g like the did with the Nexus 1. Its not like apple has released an iPhone with support for 1700mhz 3g yet.....
    Another reason why they did not include all the frequencies ever made I think is because of the same reason I think they didn't put in an SD card slot, and that would be space a phone is only so big they can't put in unlimited amounts of hardware. Why do you think they keep making everything smaller.
    Junior Member rajesh_nexusone's Avatar
    I am planning to switch over to mysimplemobile prepaid service to get 3G. i think they use Tmobile 3G(1700Mhz) bandwidth for 60$ (unlimited talk text web). have anyone else had some experience with nexus S and mysimplemobile??
  1. Text to Talk
    By DF Member in forum Samsung Vibrant
    Last Post: 02-06-2011, 01:11 AM
android only on edge no 3g
galaxy nexus edge only
net 10 no 3g nexus s
net10 edge no 3g on droid
nexus s 3g edge
nexus s edge network only
nexus s only edge
nexus s only edge connection
nexus s only showing edge
nexus s only using edge
nexus s shows edge network
nexus s solo edge
not getting at&t 3g on nexus s
only edge with at&t nexus s
why only edge with net 10
