Nexus S Only edge access No 3G
This is a discussion on Nexus S Only edge access No 3G within the Nexus S forums, part of the Google Phones category; I notice on Nexus S that there is only acces to edge when you use another carrier than Tmobile. Its this normal? Are there any ...
Results 1 to 10 of 15
Thread: Nexus S Only edge access No 3G
    Junior Member lacsat's Avatar
    I notice on Nexus S that there is only acces to edge when you use another carrier than Tmobile. Its this normal? Are there any way to change that??
    Thanks
    Simply put. there is nothing You can do. It is normal. Its a hardware issue
    Senior Member Syntax323's Avatar
    Wouldn't call it hardware issue, as this isn't an issue...
    More like a restriction.
    [ROM] Cyanogen 7 Nightly's - I've accepted that I crackflash, no rehab center is open yet... -
    [Radio]Korean Radio 5.08.00.04
    I've tried Nexus S, MT4G, and G2, and I just can't find a phone that surpasses the Nexus One. Hard to believe this came out almost a year ago and it's still top of the line. :nexusx:
    What these folks are saying is that the Nexus S does not have the hardware that supports all the 3G bands in worldwide use. As with the Nexus One, the first version of the USA Nexus S supports only T-Mobile USA 3G. The USA N1 later came out with a version that supports AT&T 3G. This may happen with the NS.
    I believe that there is circuitry available that would enable a phone to support most, if not all, 3G bands, and I think it's myopic for Google not to have included it in the Nexus S. It's a deal-breaker for me.
    I agree, it doesnt make scence to announce an unlocked phone when there is a restriction.
    But at the same time I heard that the same happen on another previous model not the nexus but another HTC I think and some hackers find the way to open the phone and they enable the 3G support. So probably is not on the hardware, maybe is a software thing.
    Junior Member spitfire's Avatar
    im pretty sure its hardware related.
    I know for a fact that it is hardware related it's because the antenna that is inside does not receive the 3G frequency band that is projected by the at&t towers just the t-mobile ones and the wind mobile ones here in Canada.
    But I thought it has support to 3G here is the Phone network info:
    2.5G (GSM/ GPRS/ EDGE) : 850 / 900 / 1800 / 1900 MHz
    3G (HSDPA 7.2Mbps, HSUPA 5.76Mbps) : 900 / 1700 / 2100 MHz
    Check this!!
    GSM World Coverage Map- GSM Country List by frequency bands
    Junior Member blaz's Avatar
    900/2100 is used in Europe, 1700 is used on T-Mobile in the US. AT&T in the US uses 850/1900, which is not supported.
    Junior Member alank's Avatar
    Nexus S is compatible on the 3G networks of most carriers in the world. AT&T's 3G network is one of the few in the world that the Nexus S does not support.
    So I would say this is more AT&T's fault and not Google's fault
  1. Text to Talk
    By DF Member in forum Samsung Vibrant
    Last Post: 02-06-2011, 01:11 AM
android only on edge no 3g
galaxy nexus edge only
net 10 no 3g nexus s
net10 edge no 3g on droid
nexus s 3g edge
nexus s edge network only
nexus s only edge
nexus s only edge connection
nexus s only showing edge
nexus s only using edge
nexus s shows edge network
nexus s solo edge
not getting at&t 3g on nexus s
only edge with at&t nexus s
why only edge with net 10
