Nexus S: 3G and WiFi Problems
This is a discussion on Nexus S: 3G and WiFi Problems within the Nexus S forums, part of the Google Phones category; Originally Posted by joe1111 Hi guys, I bought the Nexus S at Best Buy 3 days ago... Unlocked, but with Pay as you go from ...
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Nexus S: 3G and WiFi Problems
  1. #21
    Junior Member boozys's Avatar
    Quote Originally Posted by joe1111 View Post
    Hi guys,
    I bought the Nexus S at Best Buy 3 days ago... Unlocked, but with Pay as you go from T-Mobile.
    Since then I experienced some Problems: 3G doesn't really work, the Connection lasts for some seconds and then breaks down again.
    Similar Problem with WiFi... The connection breaks down after a short time, but it works fine with my notebook, so it must be the phone??
    Do you have similar problems?
    joe
    the same problems
  2. #22
    Junior Member cbicak's Avatar
    Same problem in UK
    I have exactly the same problem here in London, UK.
    I do not believe that this is a carrier issue. There is clearly something wrong with the device itself. It will be revealed and hopefully it is due to a software fault, so that google can help us out.
    It takes 30sec at least to reconnect. It is so annoying. I am thinking of bringing my phone back to car phonewarehouse.
  3. #23
    i bout yesterday a new weirless router,funy but now et home it's working.
    in general the nexus is very good phone,but google should fix few bugs.
    life is good,enjoy.it's only a phone
    Bo
nexus 3g problem argentina
nexus 4 works on 2g but not 3g
nexus 7 3g wifi problem
nexus s 3g problem
nexus s wifi problem
problem 3g and wifi nexus 7
3g nexus s
