Will Nexus S work in China?
This is a discussion on Will Nexus S work in China? within the Nexus S forums, part of the Google Phones category; Will Nexus S work in China? Will 3G work as well? If so, from which provider?...
Thread: Will Nexus S work in China?
    Junior Member jclova's Avatar
    Well your carrier is Fido I didn't know they had Fido in China but here in Canada I am on Fido with a t-mo nexus one which has the same frequency band as the nexus S but it doesn't work for 3G just EDGE but to be sure I would Google the name of all your carriers with frequency band after and compare those to the ones of the nexus S and if they are the same they it works.
    I am currently in Canada and with Fido. (Soon to change to Wind /w Nexus S)
    Just curious if I can use it in China.
    Oh ok that makes sense but like I said you will need to check which frequency band each provider uses to see if it will work on that provider.
    Senior Member Zehlek's Avatar
    I can't wait for Wind to come to Niagara Falls
    Junior Member alank's Avatar
    Yes, the Nexus S will work in China
    The Nexus S works with any GSM carrier world-wide, which means that you can buy any SIM card in China and pop it into your Nexus S.
    As far as 3G data is concerned, only China Unicom's 3G is compatible with the Nexus S. So unless you want to browse the web on 2G EDGE speeds, there's no reason to use any carrier other than China Unicom.
3g on nexus 5 in china
android doesnt work in china
android not working in china 2g
does galaxy nexus work in china
does google nexus 5 work in china
does google nexus work in china?
does nexus 5 work in china?
does nexus work in china
does the nexus 5 work in china?
how will nexus 5 work in china ?
nexus 4 will it work in china
nexus 5 phone not work in china
using a nexus in china
using nexus 5 in china
will google phone work in china
