How to switch between running apps
This is a discussion on How to switch between running apps within the Nexus S forums, part of the Google Phones category; Hi, I have a Nexus S & this is my 1st Android fone, infact my 1st smart fone. Does anyone know know how to switch ...
Thread: How to switch between running apps
    Junior Member snowy's Avatar
    Hi,
    Does anyone know know how to switch between running apps?
    My fellow Ifone friend just holds the button on the botton & the running apps list appears
    Thanx & a Merry Xmas to all - Rob
    14 times
    Try a long press on the home button. Should bring up a menu of recent apps.
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    Hi,
    Thanx for the reply, but (there always is) I tryed that but it only brings up latest apps\games used, not a list of currently running apps to allowme to switch to one of them
    Rob
    14 times
    Try Visual Task Switcher in the market. There is a free one and a paid one.
    [PHONE] Nexus 4
    [TABLET] Nexus 7
    Hi,
    thanx for the advise, I have DL'd it & will have a go later
    Thanx again - Rob
    Quote Originally Posted by snowy View Post
    Hi,
    Rob
    Those are the running apps.
    Member d4ni3l's Avatar
    I think there is no actually such thing as running apps... at least not for all of them... for example I've noticed that some games and applications start over if I press home button, and then try to get back to the game/app (no matter whether I do that via recent apps menu or just from the apps list). I guess this is because android kills apps over time (except the ones that use some method that prevents android from automatic killing them, for exampe skype)
android how to switch running apps
android how to switch to a running application
android switch to a running app
android switch to running app
cm11 how to switch application
how to see recent running apps samsung nexus s
nexus s switch between apps
running app when switch on in android
running apps on cm11
switch between apps nexus 7
