Maps app and battery consumption
This is a discussion on Maps app and battery consumption within the Nexus S forums, part of the Google Phones category; Same issue here... nexus s upgraded to 2.3.1... maps is always the top app in the battery use screen even if I've never started it ...
Results 11 to 14 of 14
Thread: Maps app and battery consumption
    Junior Member dankind's Avatar
    Same issue here... nexus s upgraded to 2.3.1... maps is always the top app in the battery use screen even if I've never started it after a reboot.
    I've disabled GPS and latitude and it seems to have helped a tiny bit, but the battery still won't last a full day.
    Is there an easy way to backup all my data and downgrade back to 2.3.0 ?
    Quote Originally Posted by dankind View Post
    AFAIK no but maybe the PASSIMG method could work but I can't tell you for sure that it won't wipe your phone I have never tried this method so I don't know. wait a minute has anyone tried the passimg method on the nexus S yet?
    Junior Member auxelf's Avatar
    you have to switch off google Latitude within google map and also kill it from running process
    Member alanudi's Avatar
    Good question. I have noticed this as well...
    I've been blaming it on WeatherBug and Latitude for their constant updating, however, changing their settings seems to have no apparent effect. It could very likely be related to the recent Google Maps 5.0 update or something else.
    ...unable to locate any answers yet on the Google Help forums...
android prefetcher service
google maps prefetcher service
google prefetcher service
maps prefetcher service android
prefetcher service
prefetcher service google maps
prefetcher service maps
prefetcher service maps android
prefetcherservice
what is google maps prefetcher service
what is maps prefetcher service
what is prefetcher service
what is prefetcher service android
