Nexus S on Rogers
This is a discussion on Nexus S on Rogers within the Nexus S forums, part of the Google Phones category; Sorry if this is in the wrong forum, the Rogers forum is classified under Nexus One so I posted here. Anyway, does anyone know of ...
Thread: Nexus S on Rogers
    Senior Member Zehlek's Avatar
    Nexus S on Rogers
    Sorry if this is in the wrong forum, the Rogers forum is classified under Nexus One so I posted here. Anyway, does anyone know of what APN I put in for data and MMS or a combo APN that does work?
    Junior Member spacemanspiff33's Avatar
    Should be the same settings you used in your Nexus One. Sorry I was on fido so I cant say for sure....I noticed in your avatar it says you will be switching to Wind, I myself just did that last night (from fido to wind) in order to be able to use 3g with the Nexus S (Currently you will get edge at best on the rogers network with the Nexus S) and because they have the $40 unlimited everything plan. Hell of a good deal, and they are only offering it until the 31st, I say forget about the APN settings for robbers and get all up with Wind!
    Quote Originally Posted by spacemanspiff33 View Post
    Thank you. I am waiting for Wind to come to Niagara Falls
