Call Blocker for Nexus S
This is a discussion on Call Blocker for Nexus S within the Nexus S forums, part of the Google Phones category; This is my first Droid phone and I'm looking for a call blocker app. Extreme Call Blocker looks promising but I think the app is ...
Thread: Call Blocker for Nexus S
    Junior Member bluejava2's Avatar
    This is my first Droid phone and I'm looking for a call blocker app. Extreme Call Blocker looks promising but I think the app is certified to only work on Froyo (2.2). Anyone out there have a call blocker app on a Nexus S?
    bluejava2
    Junior Member shanes4doorsi's Avatar
    call filter works great and its free have it on both my n1 and ns check it out in the market
    extreme call blocker
    I am using Extreme Call Blocker with Nexus S. One big problem: if i select "hang up and no voicemail", it picks up after the 1st ring (silence) and sends the caller to VM, which is not what I wanted.
    I'll check out your recommendation.
    Thanks...
    bluejava2
    Junior Member Godhelm's Avatar
    It is possible to choose to send calls from specific contacts to voicemail without any additional app. Just open a contact, click on the menu button, select Options, and check the "Incoming calls" box.
block contact nexus s
block number on nexus s
block numbers on nexus s
how do i block a number on my nexus s
how to block a number nexus s
how to block a number on a nexus s
how to block a number on google nexus s
how to block a number on nexus s
how to block a number on the nexus
how to block a phone number on samsung nexus s
how to block contacts on nexus s
how to block numbers on google nexus s
how to block numbers on samsung nexus s
nexus s block number
nexus s block phone number
