Nexus S WiFi Going Off
This is a discussion on Nexus S WiFi Going Off within the Nexus S forums, part of the Google Phones category; OK one of the first things I have noticed since getting the phone is that the WiFi seems to turn itself off intermittently. This usually ...
Thread: Nexus S WiFi Going Off
    Android Lurker Muzz Mackay's Avatar
    This usually happens after waking up and not after it's been switched on from off.
    I live in UK and have the BTfon app which pops up because it notices theres no WiFi.
    Last time it happened going to the stock far right home screen with the connection icons and tapping it off and on sorted it, but I have also had to go to settings and turn it back on.
    Android Lurker Heinrich's Avatar
    I think it normal. Mine turns wifi off on lock unless im using wifi actively
    Yeah maybe, no big deal just wasn't sure whether it was meant to happen or whether it was bug.
    Junior Member Chro's Avatar
    Yep, I'm pretty sure it's a power-saving feature. WiFi uses quite a bit of power.
    Member alanudi's Avatar
    This is a power-saving feature.
    You can change the settings here...
    Menu Key > Settings > Wireless and networks > Wi-Fi settings > Menu Key > Advanced > Wi-Fi sleep policy
    Change to "Never" so it only turns off manually.
nexus wifi turns off
wifi on nexus s turns off
