Navigation problem on my Nexus S
This is a discussion on Navigation problem on my Nexus S within the Nexus S forums, part of the Google Phones category; hi, i live in israel and i want to access navigation but it doesnt work its get stuck at checking navigation availablity... what do i ...
Results 1 to 10 of 11
Thread: Navigation problem on my Nexus S
    Junior Member Powerhead's Avatar
    hi,
    what do i do???
    Are you getting a GPS lock?
    Ne:nexusx:uS One ROOTED
    Cyanogen Mod Nightly ROM
    u mean the little symbol i get on the top? yes? explain?
    i go
    menu-> navigation->then it does checking navigation availablitly and i get a target symbol near my internrent and recepetion symbols
    Try go into Manage Applications, MAPS>Clear Data
    If that don't work, download a GPS Status and Toolbox app from market
    See if you're getting GPS lock
    nope still not getting anything its stell like loading or somthing why wont it work
    like thats the only thing left to fix tbh
    Not sure if you want to but at this point a factory reset is probably in order.
    Ok stupid question but it might be an error of inattention something similar happened to me once go to settings-> location & security then under my location make sure the two check boxes are check ("use wireless networks" and "use GPS satellites").
    Try this
    1- Menu > Settings > Applications > Manage applications; Tab "All"; Application "Maps"; Force stop; Clear cache; Clear data
    2- Reboot
    3- Opened the Mapsapplication (not Navigation) and accepted the change message
    4- Now go back to the home screen and started the Navigation application
    5- Accepted the message, that should work
    Junior Member sanjeev.gour's Avatar
    I had the same problem. Here is what I did-
    1. Tried clearing data, rebooting phone, didn't work.
    2. Searched for Maps in the Market, select update.
    3. Once the maps are updated, opened Maps.
    4. Opened navigation.
    I got rid of the Checking navigation availability message. Although it says Navigation is not available for this location, get driving directions. It solves the original problem.
    Good Luck.
    Junior Member pavelm's Avatar
    All,
    I have the same problem... I bought the phone in US and navigator worked well, but after I back to Israel - it can't detect the location any more. Powerhead... Did you solve the issue? If yes - how... I tried all suggestion above... Nothing... Navigation is not working...
google navigation wont work on my galaxy nexus
my phone gps stuck on checking navagation availability
navigation not work nexus
nexus 4, navigation doesn't work
nexus s gps stopped working
nexus s navigation not working
nexus tablet navigation stopped working
nexus-s gps stopped working
