nexus s WiFi problems
This is a discussion on nexus s WiFi problems within the Nexus S forums, part of the Google Phones category; hi everyone i bout the Nexus S in the US last week best buy. i am musician leaving in EU. back home and i notice ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: nexus s WiFi problems
    Junior Member boozys's Avatar
    hi everyone
    back home and i notice i have problems with the WiFi...
    by starting i can see that it take the signal.
    but after a second or 2,the signal is going off.
    i just can't get WiFi signal from my router.
    i had before an LG Mini and had never problem with WiFi.
    i downloded WiFi fix but i still can't see no signal on the phone
    somebody can help with this issue?
    thanks
    bo
    boozys@gmail.com
    Junior Member dryphi's Avatar
    I have a problem with my WiFi as well.
    Nexus One rooted with 2.3.1 (GB) installed.
    At my school they have a WEP-secured Wi-Fi linkup and my Nexus One refuses to connect and will sit there trying over and over again. Eventually it will get on but it's frustrating.
    I also have an iPod Touch and it connects right away, but this damn Android doesn't. I don't understand what the deal is.
    I'm sure any self-respecting Android fan would hate to admit that the iPod firmware is superior but in this case it is. I have extensive experience with both.
    I had the same problem before I updated to GB. The CyanogenMod seemed to help when I had that. Also at one point I had something called "WiFi Fixer" installed and that really did the trick but I only tried it for one day before they wanted me to pay. I shouldn't have to pay for something the Google devs should fix themselves. If an app has been made for it, that means there is a software fix, so get on it.
    Still not even fixed with Gingerbread what is wrong Google get with the program.
    Junior Member Lesley's Avatar
    I just bought a Nexus S and it will not connect to my home wi fi. It sees it and tries to connect and then says "disabled" Any ideas?
    Wifi on the new Nexus S is not all that great.
    Junior Member yayaysue's Avatar
    I have the same problem as Lesley, can anyone help?
    The Nexus will simply not log on to my home wi-fi router. It says authenticating to and then disable.
    Does the Nexus have a PIN which can help with the set-up?
    Thank you!
    Android Lurker iPeck's Avatar
    Laval, Qc
    Check your router settings. With some security or frequency config settings (dont know wich ones sadly. Maybe the 802b only mode or security encryption levels), it can conflicts the connectivity of the phone. I had the same issue at 1st when connecting to my router.
    iPeck: Thanks for replying. To be honest, I'm new to all of this so alot of it is very confusing to me.... I've been at it for 2 hours and just about fed up now! I wish it would just log in and get over with it, when I have to play around with settings then I'm lost. Been trying to read up about the issue on the net but everyone has a different solution. Confusing! lol
    Laval, Qc
    Yes, soooo many different issues with these phones
    1st, log to router and go to the settings. You'll find (somewhere, depending on your router brand) password security encryption level (wep, wpa etc..). Downgrade the level of encryption. afaik thats whats prevented me from connecting.
    If I check now, it's set to WPA only with TKIP cipher type is that what you mean?
    Laval, Qc
    yes...
    and do you see 802.1xb only mode ? if yes, uncheck it (should be in main settings, well mine is )
android wifi authentication problem
authentication problem on nexus s
galaxy nexus wifi authentication problem
nexus 10 will not log in to my wifi
nexus s authentication problem
nexus s wifi authentication problem
nexus s wifi problem
nexus s wifi problems
wifi authentication problem on my google nexus s
wifi trouble shooting nexus
