3g replaced with web2go
This is a discussion on 3g replaced with web2go within the Nexus S forums, part of the Google Phones category; All, Yesterday I tried to set up my Nexus S wireless to access my university wireless net. It hung the phone, and I rebooted. Since ...
Thread: 3g replaced with web2go
    Junior Member nsteussy's Avatar
    Exclamation 3g replaced with web2go
    All,
    Yesterday I tried to set up my Nexus S wireless to access my university wireless net. It hung the phone, and I rebooted. Since then I cannot access the net over the 3g connection. I get redirected to m.web2go.com and then to:
    http://10.184.76.164/resources/webpages/error.jsp
    and the message in that web page is:
    Error unknown
    Your homepage is temporarily unavailable...
    Googling the above shows that the web2go is a 'pay as you go service' from t-mobile. T-mobile support says they don't know why I cannot access my dataplan/3g.
    Suggestions welcome.
    Duke out
    14 times
    Check out this thread
    http://www.nexusoneforum.net/forum/n...-3g-issue.html
    3rd Post's solution might help you.
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    solved web2go
    Well, actually I don't know what happened.
    I spent 2 hours on the phone with t-mobile tech support. Then at their suggestion called Samsung for hardware support (we agreed it was a network problem).
    And then that evening the problem went away. I don't know what happened. I surmise that some switch was flipped in their cell hard/software in my area. That they found the problem and then corrected it.
forum web2go error
home.web2go.com
m.web2go.com
t http //home.web2go.com/
t mobile homepage web2go
t mobile redirects to web2go
tmobile web2go homepage
tmobile web2go url
web2go homepage
web2go homepage url
web2go redirect
web2go redirect respell
web2go t mobile homepage
what happened to t mobile homepage web2go
what happened to tmobile web2go
