Using your own ringtones, does not work.
This is a discussion on Using your own ringtones, does not work. within the Nexus S forums, part of the Google Phones category; Can someone else with a Nexus S spare the time to try this. I have created a folder on the phone called Ringtones into which ...
Results 1 to 10 of 16
Thread: Using your own ringtones, does not work.
    Android Lurker Muzz Mackay's Avatar
    I have created a folder on the phone called Ringtones into which I have placed several short MP3 files.
    I have then either used Astro or the sound settings on the phone to select one of the MP3's as the ringtone. It works until the phone is powered down and restarted upon which the phone reverts back to a system ringtone.
    there is already a folder for ringtones under sdcard/media/audio/ringtones
    mine go there when I create one from my ringtone app
    try putting them there
    ken
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    Quote Originally Posted by rugmankc View Post
    Maybe your app created the folder as I only have
    sdcard/media/audio/notifications
    Within this folder the facebook app has placed a ringtone.
    I will create the folder you mention anyway and see how I get on.
    Android Lurker iPeck's Avatar
    Laval, Qc
    If its not there just create it...
    yea, not sure if it did or not
    but, others have mentioned it being there
    hopefully creating it in that directory will work
    I am not a computer expert, can you have it there and have notifications
    ken
    [SIGPIC][/SIGPIC]
    Laval, Qc
    It should work fine, i had to do it with my phone and it works.
    thanks for the help ipeck
    [SIGPIC][/SIGPIC]
    Laval, Qc
    My pleasure
    That's done the trick, thanks all
    Laval, Qc
    Same works with notifications
