Lets try again! Radio & skype on nexus s - yes or no!
This is a discussion on Lets try again! Radio & skype on nexus s - yes or no! within the Nexus S forums, part of the Google Phones category; To all you experts out there !! please can you answer a couple of simple questions your none IT jargo help would be really appreciated. ...
Thread: Lets try again! Radio & skype on nexus s - yes or no!
    Junior Member cjb dublin 7's Avatar
    QUESTION 1:
    I HAVE A NEXUS S PHONE. CAR-PHONE WAREHOUSE SAID THAT IT'S POSSIBLE TO DOWNLOAD AN FM RADIO WITHOUT INCURRING DATA AND STREAMING COSTS? IS THIS REALLY POSSIBLE AND HOW DOES ONE DO IT? SIMPLE DIRECT ANSWER PLEASEEEEEEEEEEEE;
    QUESTION 2:
    I HAVE A NEXUS S PHONE. IS IT POSSIBLE TO DOWNLOAD SKYPE VOIP TO MY NEXUS PHONE? AND USE SKYPE AS MY PHONE FROM NEXUS S ?
    Helpful replies would be very much appreciated : Pleaseeeeeeeeeeeeee !!
    Metro Atlanta
    53 times
    Moved post to Nexus S section for more exposure.
    14 times
    1. Root and wait for CM7 is the only way I know
    2. Not at this time.
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    Junior Member gcol's Avatar
    Hmmm, I've got Skype running on my Nexus S without any problem.
    14 times
    And your using voip?
    [PHONE] Nexus 4
    [TABLET] Nexus 7
    14 times
    Seemed to me that the OP wanted to Run Skype instead of having an actual phone plan thru a carrier. I do not believe that is possible.
    Never said you couldnt download skype to the Nexus S
    [PHONE] Nexus 4
    [TABLET] Nexus 7
    Junior Member Discosis's Avatar
    Gingerbread supports SIP, so you could use the phone without actually signing up to a carrier if you're always within range of a wifi access point.
    If you're within range of a wifi access point, you could also just use Skype anyway.
    If you're out and about, unless you happen to have constant wifi coverage from access points you have permission to use everywhere you go, you're going to need a data plan at the very least or else your phone won't be contactable as you move out of range. You could use the SIP support but over mobile data it's probably going to be a bit hit-and-miss.
