Nexus S in car holder?
This is a discussion on Nexus S in car holder? within the Nexus S forums, part of the Google Phones category; I'm thinking of buying Brodit holder for the Nexus S .. Anyone with any other alternative recommendation?...
Thread: Nexus S in car holder?
    Android Lurker essandroid's Avatar
    I'm thinking of buying Brodit holder for the Nexus S.. Anyone with any other alternative recommendation?
    Junior Member sawyer's Avatar
    Apr 2011
    How about this one...
    Samsung Nexus S Car Mount Cradle
    Junior Member massage_girl's Avatar
    KIDIGE brand car mount for Nexus S.....
    Quote Originally Posted by sawyer View Post
    Has anyone used this KIDIGE brand car mount? What has your experience been with it? Not a lot of info on website. How does this mount in car?
    I had suction mount for my HD2 that was made by Kidigi, and I recall I had problem, when I plugged my device into the holder, it kept on displaying error message, an I returned it back. To be honest, that was a wile back and I am sure things must have changed and improved.
    Junior Member robbiegrewal's Avatar
    official samsung car dock
    Nexus S in car holder mount
    Brodit are best when it comes to mounted in car holder. However, as my other half and I have two different phones and share one car, I decided go slightly different route and install Brodit ProClip in my car, and installed Herbert Richter universal holder onto it using this adaptor plate. Works perfectly for us and as ProClip is already installed, should I wish to install Brodit holder later stage, I can do that without any problem.
    Banned Waterbeds's Avatar
    Jun 2012
    i have been using this Nexus S car mount, its made by naztech and works perfectly the dual usb car charging adapter makes it even that much better...
nexus 7 car install proclip
nexus s car mount
