Best app to help Battery life?
This is a discussion on Best app to help Battery life? within the Nexus S forums, part of the Google Phones category; I was wondering what everyone would recommend to help with battery life. At the moment I am currently using Advance Task Manager and Open Advanced ...
Thread: Best app to help Battery life?
    Senior Member Zehlek's Avatar
    I was wondering what everyone would recommend to help with battery life. At the moment I am currently using Advance Task Manager and Open Advanced Task killer
    Sent from my Nexus S using Tapatalk
    Personally, I would nix the task manager apps and just use the system provided manage apps and kill off the annoying apps (Nexus Ones have Amazon MP3 for example).
    To put it bluntly, you are wanting a rec on an app (that uses battery) to save battery life.
    Junior Member boozys's Avatar
    stop the WiFi if you don't using it,it help a lot.
    Android Lurker Lionsson's Avatar
    If you have Android 2.2 and above you really don't need a task manager. If you go to an empty spot on you launcher (desktop) and long press, select shortcuts, select settings,and select battery use. You should notice thar your screen is above 75 percent of the battery use. If you find an app that is (compered to the rest of the apps) excessive uninstall it or try to find a replacement.
    Android Lurker iPeck's Avatar
    Laval, Qc
    Quote Originally Posted by lionsson View Post
    That's why my phone is always set to 0%, I set it to 25% when need little more bright and it's VERY rare that I need to set it to more than 50%.
    The small free Brightness level widget is a savior for me Mixed with WiFi OnOff, GPS OnOff and APN OnOff widgets (one touch disablers), I do have a pretty good battery life.
    With Beautiful small clock and weather widget, these are the only widgets I use to then again, restrain battery use. And of course, no task manager.
    cm 6.1.x ftw
    I have personally witnessed the HUGE difference
app for battery saver for nexus 7
battery saver app for nexus 7
battery saver app for nexus s
best android battery savers for google nexus 4
best app to help draining battery on droid dna
best app to save battery life android
best battery app android
best battery app for galaxy nexus
best battery app for nexus 7
best battery app nexus 7
best battery saver app for nexus 7
best battery saver for galaxy nexus s
do you really need a battery saver app for google nexus 4
the best battery saving app for nexus 4
what is best app t help save battery life on droid
