Hi, got 2 questions about my new Nexus S.
1. Was getting bad battery life, and through help on twitter found I have the /init issue which chews up power, so have enabled USB to stop it. Is this a bug that Google are fixing does anyone know?
2. Obviously phone comes with all the stock google applications, will these auto update or should I install them again from the marketplace to make sure I get the latest versions?
