Nexus S Pattern Lock
This is a discussion on Nexus S Pattern Lock within the Nexus S forums, part of the Google Phones category; Nexus S Pattern Unlock , There is no clear storage option in the menu How do i remove the pattern unlock? Thanks...
Thread: Nexus S Pattern Lock
    Junior Member shak360's Avatar
    Thanks
    Metro Atlanta
    53 times
    I have the N1, but what you look for should be under Settings>Location & Security>Screen unlock>set up screen unlock>None
    And welcome to the forum! We're glad you're here, and hope we can help with anything you need.
    Thanks for your response, but ive forgotten the pattern lock sorry i shud av posted tht earlier much apoligies
    Im Just getting use tio the andriods x(
    If you forgot the pattern lock then just input it badly multiple times then you will be prompted to sign in to the phone using your Google credentials. Then you can change the lock pattern.
forget lock pattern for nexus 4
forgot lock pattern on nexus s
how to remove pattern security from android nexus s
how to reset pattern lock nexus s
how to unlock google nexus s pattern
how to unlock nexus asus with pattern lock on
how to unlock pattern lock on samsung nexus s
i forget pattern to unlock samsung nexus s
nexus 4 forget pattern
nexus s pattern lock forgot
pattern lock nexus
samsung nexus s pattern unlock
unlock pattern of samsung nexus s
unlock pattran gogle nexus s
www.android.net 107258-nexus-s-pattern-lock
