Nexus S won't turn on!!
This is a discussion on Nexus S won't turn on!! within the Nexus S forums, part of the Google Phones category; Hi Everyone. I have my Nexus S for a 3 days - it's brand new. Last night i turned it off. It was about 50% ...
Thread: Nexus S won't turn on!!
    Junior Member ubootx's Avatar
    Hi Everyone.
    I have my Nexus S for a 3 days - it's brand new. Last night i turned it off. It was about 50% charged. Today i can't turn it on. Phone is dead. What's wrong? There is no any response, even during charging (black screen).
    Phone wasn't rooted. It has Android 2.3.2 update.
    Junior Member 2legitoquit's Avatar
    Hey, I just had a similar problem, mine just cut off while it was still on with a 90% battery. Now cant turn on and no response while charging either.
    Looks like a manufacturer issue.
    Metro Atlanta
    53 times
    @ubootx: Your battery is probably dead. Try using an AC charger instead of USB, and let it go for a while before you try to start it.
    @2legit: yours seems like a different issue, and one I hope you can get fixed.
    Took the battery out for a minute and tried to turn on again, all is well.
    Metro Atlanta
    53 times
    Whew! Glad to hear it, 2legit!
    Junior Member mmontecchi's Avatar
    Apr 2011
    Hey, I have the same problem!!!
    My Nexus S is 2.3.3, not rooted.
    Massimo
    Junior Member keygoddess's Avatar
    Apr 2011
    I had the same problem not long after getting mine .... took it back to best buy and they opened it and removed battery, reinstalled battery, replaced cover and it was fine. It hasn't happened since.
can't turn on nexus s
google nexus s 4g wont turn on
google nexus s wont turn on
google nexus wont turn on
my nexus s wont turn on
nexus s 4g won't turn on
nexus s 4g wont turn on or charge
nexus s can't turn on
nexus s cannot turn on
nexus s won't turn on
nexus won't turn on
samsung google nexus wont turn on
why won't my nexus turn on
why wont my nexus turn on
