Nexus S USB problem
This is a discussion on Nexus S USB problem within the Nexus S forums, part of the Google Phones category; Hi Wonder if anyone can help. Connected my Nexus S for the firs time to my PC running windows 7 32 bit via USB. Phone ...
Thread: Nexus S USB problem
    Junior Member thedoswells's Avatar
    Nexus S USB problem
    Hi
    Connected my Nexus S for the firs time to my PC running windows 7 32 bit via USB. Phone says USB connected, with option to turn on USB storage.
    However, PC does not seem to recognise the phone at all.
    It says there is a new USB device, but then nothing shows in explorer at all.
    Downloaded the SDK and included new USB driver revision 4 (which says it has Nexus S support). Still nothing.
    Any ideas?
    Thanks
    Steve
    Junior Member bugmenever's Avatar
    Have you pushed the button: "Turn on USB storage" ?
    Quote Originally Posted by bugmenever View Post
    Hi, thanks - yes I've done that. I've now uninstalled the SDK and drivers and re-installed. It now seems to work most of the time! However sometimes it seems to take 3 or 4 attempts to connect. Could be a cable issue, so I'll try another.
    Many thanks for your post
    Steve
how to fix usb port on nexus s
how to turn on usb storage on nexus s
nexus s bug usb
nexus s usb connection problem
nexus s usb storage not loading
usb storage not working on nexus s
