Nexus S GPS antenna
This is a discussion on Nexus S GPS antenna within the Nexus S forums, part of the Google Phones category; Originally Posted by alzakx Originally Posted by damien8 Wondering if I have this same issue... I turn on the GPS, go to navigate, and then ...
Results 11 to 17 of 17
Thread: Nexus S GPS antenna
    Member damien8's Avatar
    Quote Originally Posted by alzakx View Post
    Quote Originally Posted by damien8 View Post
    I turn on the GPS, go to navigate, and then it says "Searching for GPS" and it pretty much hangs there. It sometimes establishes the connection, but usually not.
    Is this what you guys are experiencing?
    yep, was the same issue for me on any GPS app until 2.3.4.
    I'm with Telus (Canada).
    Anyone happen to know when the 2.3.4 will be coming out?
    So, did 2.3.4 fix the GPS completely?
    Senior Member shibby_nexusone's Avatar
    im on 2.3.4 on my nexus s 4g and have the same problem cant ever find location on 3g
    rooted Nexus S 4G
    Quote Originally Posted by shibby View Post
    I'm on 2.3.3...
    So the problem still exists in 2.3.4?
    I'm on 2.3.3...
    looks like it my G2 never had a problem even on edge it only took a few seconds this seems to be the only thing i dont like about this phone
    rooted Nexus S 4G
    Junior Member xxx007xxx's Avatar
    Jun 2011
    A-gps
    To improve your gps use apps like GPSfix or GPS status to update the Assisted gps info it should fix in less than 15 sec after this.
    Junior Member steve457_nexusone's Avatar
    hey guys,
    i am experiencing the same problems & 1 have the latest version 2.3.4
    have tried several different gps apps.&get the same results
    Howdy.
    I'm just here to report that after the recent 2.3.4 update my nexus s has been locking on the gps very quickly. I've tested it enough to say that the issue is fixed.
    Thanks google.
    the gps problem is deffinatly not fixed.i have the 2.3.4 and gps still does not work with any app with the exception on g-maps. all locations need to be loaded by zip code if the app will let u.
    u guys really need to fix this...thanks
compass vs gps
external gps for nexus 10
gps antenna for android
gps antennae nexus 4
nexus gps antenna
nexus i515 gps antenna location
nexus s external gps antenna
nexus s gps antenna
nexus s searching for gps#gsc.tab
upgrade nexus 10 gps antinna
where is nexus 4 gps antenna
