Nexus S - Android 2.3.3 Phone Prompt Issue
This is a discussion on Nexus S - Android 2.3.3 Phone Prompt Issue within the Nexus S forums, part of the Google Phones category; he, before i upgraded to 2.3.3 i was promoted on my first phone call (while wifi was available) if i wanted to make modibe phone ...
Thread: Nexus S - Android 2.3.3 Phone Prompt Issue
    Junior Member absterok's Avatar
    Apr 2011
    he, before i upgraded to 2.3.3 i was promoted on my first phone call (while wifi was available) if i wanted to make modibe phone call or internet call, this happens even when sip not configured, but before 2.3.3 i was able to tick a box that stopped it asking.
    this feature seems to be removed now and im plaged with the prompt, if i select internet call it says not configured.
    anyone know how to stop this?
    thanks
    scott
    UPDATE
    thanks for the reply, it prompted me to try changing a setting under SETTING/CALL SETTING, USE INTERNET CALLING, changed to only use for internet calls instead of prompt for each call, i guess this is a slight bug as i dont have this feature setup at all.
    thanks all
    14 times
    Are you using Google Voice? If so Check those settings there should be a way to turn it off there.
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    14 times
    *Thread moved to correct section*
    [PHONE] Nexus 4
    [TABLET] Nexus 7
  1. Samsung Teases us Once Again with Froyo
    Last Post: 01-03-2011, 04:53 PM
android prompt cell or internet call
disable internet calling android
how to switch off internet call on android
turn off internet calling android
