computer doesn't recognize nexus s
This is a discussion on computer doesn't recognize nexus s within the Nexus S forums, part of the Google Phones category; Hi; Brand new Nexus S. Computer recognized phone the first time, now nothing. USB storage icon doesn't show up on phone when cable connected to ...
Thread: computer doesn't recognize nexus s
    Junior Member Bob20000's Avatar
    Apr 2011
    Hi;
    Brand new Nexus S. Computer recognized phone the first time, now nothing. USB storage icon doesn't show up on phone when cable connected to computer, computer doesn't recognize phone either.
    Any suggestions.
    I'm clueless and currently living in a foreign country, so this forum is pretty much my only lifeline.
    Thanks
    Bob
    Apr 2011
    I've contacted Samsung support 3 times.
    I've been told if you're running a 64 bit OS (Windows 7 in my case) the Nexus S won't work with your computer.
    Way to drop the ball, Google and Samsung
    Junior Member Pabs's Avatar
    Jun 2011
    I wish that I would have read this before I purchased this phone. This is my first "smart phone" and I am not happy that it is only as smart as the people in charge of programming. Is there a plan to fix this or do I need to get an old phone and an old computer? Thanks Google.
    Junior Member jhassell23's Avatar
    I'm sitting here with 2 Nexus S's hooked to my laptop and it reads one phone but not the other and its on a 64 bit so does somebody know what the dif would be between these 2 phones?
    Junior Member heldracul's Avatar
    Nov 2011
    Reboot
    I had a similar problem, I restarted my phone and it worked again
    Junior Member surdu_petru's Avatar
    Nov 2011
    Hi!
    I have the same problem for about four days. I do not think there is any solution!!!
    More : USB and ADB Not recognized on Nexus S I9023 ??? - xda-developers
    Junior Member Badger_nexusone's Avatar
    Feb 2012
    Nexus s USB Woes
    I had the same problem. The phone became and "unknown device". No matter what driver i accessed, connection i cleaned, nor how many reboots i tried, nothing changed!
    The error message in the device manager was "Code 43 Windows has stopped this device because it has reported problems"
    Found an MP3 forum with the fix!
    " I had code 43 problems with my usb ports until I found a thread on MSI's website. My front panel usb ports connected to a 9 pin usb header on the motherboard. Only 8 pins are needed. If pin 9 has a black ground wire then remove it. I didnt give this fix much hope but it fixed my problems! Good luck."
    This worked for me after hours of frustration. (I just used one the back usb ports!)
    I sincerely hope this trick helps you too
computer does not recognize nexus 7
computer doesn't recognize nexus 4
computer doesn't recognize nexus 7
computer doesn't recognize nexus cell phone
computer doesnt recognise nexus 5
computer doesnt recognize nexus 4
computer won't recognize google nexus 7
computer won't recognize my google nexus tab
computer wont recognie phone video nexus
my nexus 5 says its connected to my computer but my computer doesnt recognize it
my nexus s doesn't show up when plugged into the computer
nexus s unknown device
pc won't recognize nexus 7
samsung nexus s usb device not recognized
usb device not recognized when plugging nexus s on pc
