Fastboot mode - no boot or recovery img **help**
This is a discussion on Fastboot mode - no boot or recovery img **help** within the Nexus S forums, part of the Google Phones category; Hi I've searched for a solution but didn't find one for my problem so... I was trying to flash an updated kernel through Kernel Manager ...
Thread: Fastboot mode - no boot or recovery img **help**
    Junior Member dbenyakar's Avatar
    Hi
    I was trying to flash an updated kernel through Kernel Manager application and then it said it cannot complete task and asked me to reboot system.
    I then entered into the recovery and flashed the kernel manually.
    When rebooted system I got the message "FASTBOOT MODE - NO BOOT OR RECOVERY IMG" in red at the top of the bootloader.
    So naturally I thought maybe it lost the recovery so I went and flashed CWM recovery 3.0.2.5 (had 3.0.2.4 when all this happened) through fastboot and that went OK.
    I then entered the recovery to make sure the recovery flashing went OK and pressed Restart system now.
    But then it started the bootloader and the same message appeared "FASTBOOT MODE - NO BOOT OR RECOVERY IMG" in red at the top of the bootloader.
    I repeated that process few times and same thing.
    The strange thing is when I select "REBOOT BOOTLOADER" and it boots into bootloader I see "FASTBOOT MODE" in red at the top. But when I try to reboot the phose I see the message to the top again.
    How can I get out of this?
    Ok well repeat the same process with Amon-Ra instead of clockwork mod and see what happens.
    Passimg to restore your phone...
    Junior Member heliosue's Avatar
    Dbeny...
    I hesitate to offer help when I know so little, but I think I'm about one step ahead of you in restoring my Nexus S. I was able to use fastboot to get Clockwork Recovery on my phone using the following command:
    C:\android\tools>fastboot boot recovery.img
    You have to have your phone connected to your PC and be in fastboot mode, and you have to have the correct path to your recovery image. ( I have a good recovery image that I downloaded from somewhere. )
    If yours worked like mine, the Recovery image downloaded and my phone rebooted into CWR recovery. All that being said, now I'm stuck because I can't figure out the correct ROM and the correct command to get it on my internal sd card. Right now, when I work my way to my sd card using CWR, I just get " /.. " BTW, ADB only works for me when I'm in CWR so I have to keep booting that boot.image whenever I want to use ADB
    Good luck!
    Heliosue
    No matter what you do with all the good advice, don't use CW 3.
    If you don't go with Amon uselatest CW 2.
    [SIGPIC][/SIGPIC]
    San Francisco Giants
android no boot
android no command on boot
asus droidboot 2.0 fastboot online
fastboot mode - no boot or recovery img
fastboot mode no boot or recovery image
fastboot mode no boot or recovery img nexus s
how to get android tablet p1698 no bus message from booting mode
lgg2 fastboot stuck no recovery now downloader mode
nexus 7 no fastboot help
nexus s no boot and recovery img
nexus s no boot or recovery img
no boot no recovery image in fastboot mode
no fastboot no recovery how to restore cell phone
restore fastboot toshiba thrive
