Nexsus S not visible when connected to PC
This is a discussion on Nexsus S not visible when connected to PC within the Nexus S forums, part of the Google Phones category; My N1 has the same issue. NO computer will recognize my Nexus one. Is there a downloadable APK that will help my N1 communicate that ...
Results 11 to 15 of 15
Thread: Nexsus S not visible when connected to PC
    Junior Member 1hen2ducks's Avatar
    Is there a downloadable APK that will help my N1 communicate that it's there waiting to connect ?
    The computer isn't the issue. I'm unable to get to the root at this point.
    Have you tried different cables?
    I'm sure I have used other cables at some time but just for you, I'll go buy some spare MICRO-USB cables in the morning.
    Where do they go, I had several right here ?? Scratched head.
    Thanks, Mike
    Bought new Belkin cable.
    No change; still can't connect to computer. I don't think it's the computer's fault; it's the N1 phone that's the issue.
    This has become a non issue as HTC has said; the SD card is all the access you get til rooted.
    Thanks everybody for your continuing support.
    1hen2ducks
    Dazed, confused and still not rooted
cannot connect nexus s to pc
computer+not+recognizing+nexus s
google nexus s not connecting to pc
how do i make nexus 4 visible on computer
how to connect a google nexus s to pc if it wont connect
how to connect nexus s to computer
how to connect nexus s to pc
how to connect samsung nexus s to computer
make nexus visible for pc
my pc do not recognize the nexus s
nexus s usb not visible
samsung nexus s not connecting to the pc
samsung nexus s usb storage
unable to connect nexus s to pc
