Nexus S 4G on Boost Mobile?
This is a discussion on Nexus S 4G on Boost Mobile? within the Nexus S forums, part of the Google Phones category; How would I get a Sprint Nexus S 4G phone working on Boost Mobile? Do I need to flash or unlock or anything? Or just ...
Thread: Nexus S 4G on Boost Mobile?
    Junior Member sterken's Avatar
    Jun 2011
    How would I get a Sprint Nexus S 4G phone working on Boost Mobile? Do I need to flash or unlock or anything? Or just give the imei to Boost Mobile?
    As long as the frequencies match then your good. To check just lookup the frequencies from your carrier and check to see if the match with those of the NS 4G.
    I'm pretty sure boost uses Sprint cells, so my guess is he'd be okay. Virgin also uses Sprint for a lot of their cells, although they do have their own in most major metropolitan areas.
    The problem I see is the 4g. Does Boost even have that?
can i use sprints nexus s 4g with virgin mobile
do boost mobile have the nexus phone
flash nexus s 4g to boost mobile
how to flash a nexus s 4g from sprint to boostmobile
how to flash nexus s 4g to boost mobile
how to flash nexus s for boost
how to flash sprint nexus s 4g to boost
how to unlock nexus s 4g sprint to boost mobile
nexus 4 boost mobile
nexus 5 boost mobile
nexus s 4g boost mobile
nexus s 4g boost-mobile
nexus s 4g on boost mobile
unlock nexus s 4g boost mobile
unlock nexus s 4g to boost mobile
