Nexus s battery drain
This is a discussion on Nexus s battery drain within the Nexus S forums, part of the Google Phones category; Can anyone help. I have a Nexus s with very bad battery drain. Fully charged at 09:30P.M., not used overnight and with gps,Wi-Fi,sync and bluetooth ...
Thread: Nexus s battery drain
    Junior Member DublinCasy's Avatar
    Jun 2011
    gps,Wi-Fi,sync and bluetooth off and data not enabled and using 2G only.
    In the morning at 07:30 the battery is completly drained.
    Help please!
    Junior Member InfinitiGuy's Avatar
    I found I was getting very poor battery times as well until I disabled the "Receive calls" option in the built-in SIP (VOIP) client. I don't have a SIM in this phone and I was primarily testing the VOIP capabilities.
battery draining nexus 10
is it bad to fully drain batter on google nexus
nexus 10 bluetooth drain
nexus s battery drain
nexus s battery drain gps
