Wierd Camera Question/Issue?
This is a discussion on Wierd Camera Question/Issue? within the Nexus S forums, part of the Google Phones category; When you take a photo with the camera on the Nexus s, holding it standard, portrait orientation, that the phone normally is, then send that ...
Thread: Wierd Camera Question/Issue?
    Junior Member dianehelen's Avatar
    Jun 2011
    When you take a photo with the camera on the Nexus s, holding it standard, portrait orientation, that the phone normally is, then send that picture to anyone, it turns in on its side.
    IF you take the picture, with the camera on its side, it sends the picture correctly?
    Is this just the nature of the camera on this phone, or is there some setting to adjust that?
    TIA
    Diane
    That is just the way the camera is...
    Junior Member scrumshus's Avatar
    Well that doesn't happen to me
    Junior Member SSHaze's Avatar
    Mine turns it upside down.
