Battery wont charge beyond 94%...Help!
This is a discussion on Battery wont charge beyond 94%...Help! within the Nexus S forums, part of the Google Phones category; I bought my Nexus S 3 days back. On the 1st day I drained the battery and put it to charging in the night..After 3.5 ...
Results 1 to 10 of 10
Thread: Battery wont charge beyond 94%...Help!
    Junior Member Karan89's Avatar
    Jun 2011
    Unhappy Battery wont charge beyond 94%...Help!
    On the 1st day I drained the battery and put it to charging in the night..After 3.5 hours of charging,it reached 94% and stopped charging.
    The Batter Status said 'Fully Charged' and Battery Level was 94%.
    This situation repeats itself every time I have been putting it to charge.
    My phone somehow just doesn't go up to a 100% charge.
    I also installed the 2.3.4 Gingerbread OTA update that was available and its still the same..:-(
    I'm freaking out here...Should I ask for an exchange from the dealer or the Samsung service center?
    Please help me out...
    Android Lurker iPeck's Avatar
    Laval, Qc
    Just call htc, tell them you have a faulty battery, they should send you a replacement battery at no cost. (Thats what I did)
    Jun 2011
    But I read somewhere its a bug in the phone...Anybody out here facing the same issue?
    Coz when I stop charging at 94,switch charging on again,it goes to a 95 and then shows Fully Charged...
    Is this a faulty phone..coz from what I'm reading everywhere,I feel I made a mistake buying this over the Galaxy S....
    Junior Member chimpuz's Avatar
    Jun 2011
    I too am having same problem. max 95% on the battery and it shows fully charged
    Jun 2011
    Where are you from?
    have you called Samsung yet for a replacement or sumthing?
    Laval, Qc
    I thought it was htc nexus one. D'oh ! lol my bad hehe
    Junior Member thesteve's Avatar
    Are you using the Alarm Clock 2 app? When using that my Nexus S goes 94% max, when switched off it goes to 100%
    Jun 2011
    @ Ipeck : No problem man..Thanks for your prompt reply!
    @ thesteve : Nope,I dont have the alarm clock app installed...
    This problem was there since day 1,when I tried charging it for the 1st time...
    Junior Member Ringdove's Avatar
    Hi Karan89,
    it is a default system setting set by the phone itself, the battery will not charge over 95% in order to protect ur battery life.
    The time at which the battery stays at [maximum charge] should be as short as possible. Prolonged high voltage promotes corrosion, especially at elevated temperatures. [Source: Battery University]
    Yup once the battery reaches full capacity the charger stops (to avoid undue wear on the battery). The battery will discharge down to ~90% before the charger kicks in again.
    On Nexus One we were able to run off of wall power once the battery was charged, significantly reducing the speed at which the battery discharged once full, and improving the chances of it being 99-100% when you took it off the charger. Nexus S has a different charge circuit configuration which does not allow it to operate in this mode. [Source: Xda-Developers]
    In addition, u will not have to worry about unplugging the charger whenever the battery reaches the full capacity, as Nexus S battery configuration will automatically stop the current when the battery is above 95%, and will only charge again if you use it below 90%.
    Junior Member crpavan_rao05's Avatar
    hey Ringdove,
    ya i also have the exact same issue!!!......but wat i tried was enabling the "keep the screen awake while charging".....by doing so the phone charges upto 98% n sometime even 100%...... hope this helps other who are using nexus s wit the same issue!!! ....
battery doesnt charge to full capacity on my pbone s
battery stuck on 95% charge
battery won't charge past 95% samsung galaxy
charging phone stop 94
my phone doesn't charge beyond 94 percent
my s4 doesn't charge past 94%
new samsung battery doesnt charge to maximum
phone stops at 94%
phone stops charging at 94
phone stops charging at 95
phone won't charge past 94%
phone wont charge past 95
samsung galaxy tab s2 battery wont charge to 100 percent
why does my phone charge until 94% only.
why my phone cant charge above 90%
