Nexus S Camera Flash Always Off
This is a discussion on Nexus S Camera Flash Always Off within the Nexus S forums, part of the Google Phones category; When I select the option to enable the camer's flash, the only thing highlighted is the "off" function. Nothing I try enables me to select ...
Thread: Nexus S Camera Flash Always Off
    Junior Member conasabi's Avatar
    When I select the option to enable the camer's flash, the only thing highlighted is the "off" function. Nothing I try enables me to select "auto" or "on."
    Any suggestions?
    I am new to the site and can't figure out how to delete a post but I figured it out.
    Also new to Android.
    I forced the camera to stop (in the manage apps area) and then hit "clear data". Works fine now.
    Well welcome to the forum
    Now I'm not sure but if I recall correctly you can delete posts but not threads so that's probably why you couldn't find the option.
    Junior Member crpavan_rao05's Avatar
    hmmm....i guess u would have changed the scene mode......which comes under the first setting tab.....change it to auto then the flash will work....cos even i had done tat mistake once n was very worried for the same reason!!!!
    Junior Member WelenScos_nexusone's Avatar
    Apr 2012
    ____________________________ camera flash camera flashes digital camera flash
android camera flash always on
google nexus cant turn camera flash on
google nexus s camera flash
how to turn on flash on nexus s
