GPS problem.
This is a discussion on GPS problem. within the Nexus S forums, part of the Google Phones category; Hi guys I have the gps issue. Every minute when I turn on my gps it can disconnected and it takes too long for connect ...
Thread: GPS problem.
    Junior Member d3one's Avatar
    Sep 2011
    GPS problem.
    Hi guys
    I have the gps issue. Every minute when I turn on my gps it can disconnected and it takes too long for connect to the satellites.
    After reboot the gps works fine but it pissed me off.
    I want it to work without reboot (If it possible)
    Btw my English is not so good sorry :/
    Senior Member Luq07's Avatar
    Turn on Wifi before you turn on your GPS.
    There's also a number of quick GPS fix apps on the market...
android gps problem
