USB connection
This is a discussion on USB connection within the Nexus S forums, part of the Google Phones category; my nexus doesn't recognize a USB connection. I plug it into the computer an nuthin happens. any helpwould be greatly appreciated!!...
Results 1 to 9 of 9
Thread: USB connection
    Junior Member dubl69D's Avatar
    Oct 2011
    Unhappy USB connection
    You're probably not rooted, so try these ideas
    Pull Battery
    Pull SD Card
    Does phone recognize sd card in settings
    reformat and partition card fat32
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    Oct 2011
    my card is builtin
    Sorry missed the Nexus S
    Not sure then--you can still pull battery
    If under wty take to store or exchange if no good ideas
    [SIGPIC][/SIGPIC]
    Oct 2011
    did that already, do you kno if any drivers are needed??
    not that I am aware of, I have the N1
    If you can't connect to pc, not sure how that would work
    Did you do anything recently you can undo as in new apps etc
    [SIGPIC][/SIGPIC]
    Oct 2011
    someone called me an it just poped in, I probably shouldn't worry about it unless it does it again, you think?? Thanks!!
    Oct 2011
    Hey, if I want to put a movie on it, do you know what folder I would put it in or just make a new??
    glad you got it
    i just have a "Video" Folder on SD card--don't remember if i made it or it was there
    since you are dragging to card, i assume, how ever you want to do it
    [SIGPIC][/SIGPIC]
android doesn't recognize usb connection
android nexus 5 usb connection
android tv is not recognizing usb connection
android usb connection settings
broken nexus 4 doesn't recognize usb connection
google nexus i plug usb into computer and nothing happens 2015?
nexus 4 not recognizing usb connection
nexus 5 not recognizing usb connection
nexus not recognizing usb internet
nexus+s+doesn't+recognize usb
nexxus 5 not recognizinng usb connection
recognize android usb connection
usb connection settings android 5
using computer internet connection for nexus 5 using usb
