Water Damage - Red lines on screen
This is a discussion on Water Damage - Red lines on screen within the Nexus S forums, part of the Google Phones category; My Nexus S was submerged in water for a few minutes. Within an hour, I placed it in a Ziploc bag filled with rice and ...
Thread: Water Damage - Red lines on screen
    Junior Member cmd06's Avatar
    Unhappy Water Damage - Red lines on screen
    My Nexus S was submerged in water for a few minutes. Within an hour, I placed it in a Ziploc bag filled with rice and let it sit for 48 hours under a warm desk lamp.
    I tested the device just now. Almost everything on the phone seems to be working fine: WiFi, sound, soft keys, etc. However, the screen has thin red lines that look like splotchy clouds.
    Before, the ICS WiFi icon was gray when initializing, but now it looks orange when first connecting to my router. Also, any image in my Gallery that has red seems to 'glitter' with faint red lines. The default ICS wallpaper with chroma/rainbow colors looks particularly bad on the red side.
    Might sticking my phone back into the rice for more days fix this issue or this is permanent screen damage?
    Junior Member AslanMajor's Avatar
    Jun 2012
    Why was it under the water for so long? I'm not so sure about this so I'm going to ask anyway: Are those phones supposed to be water proof? It just seems like so much for something that wouldn't even work the way it was intended to. And if it wasn't meant to be waterproof, then why are you putting it in water for hours at a time?
    Junior Member lordchaos1's Avatar
    Jul 2012
    Your phone's screen
    Once water damage has occurred to that extent, it will be permanent! Sorry about your phone, but you're lucky it still works at all. If you would have tried turning it on immediately after it was submerged, then you would have completely fried the device.
    Junior Member Jazz555's Avatar
    Jan 2013
    I think it should be recovered.
andriod submerged in water
faint red line samsung galaxy 3
galaxy s water damage red screen
google nexus 4 submerged in water
google nexussubergednwter
my andriod device shows red lines around the screen
nexus 4 sumerged in water
phone has red streaks through it why
phone screen has red lines
red line on my phone screen
red line on phone screen
red lines on screen htc incredible
samsung galaxy s water damage red screen
water damage screen lines
why is my phone screen red
