Any Nexus S users on the forum?
This is a discussion on Any Nexus S users on the forum? within the Nexus S forums, part of the Google Phones category; Originally Posted by krk Well I've sent the report in to the OS people with the readout which showed the situation so no doubt they ...
Results 21 to 30 of 35
Like Tree1Likes
Thread: Any Nexus S users on the forum?
  1. #21
    Android Sr Member Droid DOES!!'s Avatar
    2 times
    Quote Originally Posted by krk View Post
    Well I've sent the report in to the OS people with the readout which showed the situation so no doubt they will have kicked it around.
    Sent from my Nexus S using Android.net
    That would DEF be an OS issue. Bring on root and custom ROMs!
    This thread has been Thunder struck!!
  2. #22
    Somewhere on Kamino
    83 times
    What are you considering to be poor battery life? And are you using task killer to kill the gallery app?
  3. #23
    Android Lurker sidharthdas003's Avatar
    Jun 2011
    India
    My first android phone and am pretty happy with it....dedicated graphics,2.3 gingerbread, smooth operations....looking ahead to latest apps
  4. #24
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    A lot of times if it's the Gallery that's eating your battery up, it's trying to index or create a thumbnail image of something that it can't read. Like an unsupported image or video format. Those will hang the app and cause high CPU usage, draining the battery. I've had that problem myself. That and Mediaserver eating my battery.
  5. #25
    197 times
    FurryVarmint
    I've had the mediaserver problem -- but not since early FroYo builds.
    DO NOT WRITE IN THIS SPACE
  6. #26
    Somewhere on Kamino
    83 times
    And it's a pure Google experience phone! Sorry, had to
    Rooted vibrant never had issue. *knocks on wood*
  7. #27
    krk
    krk is offline
    Android Lurker krk's Avatar
    I noticed the battery indicator dropping in less than a day. The battery use screen showed 85% use by the gallery. I tapped through to the app and used "forced stop " then filled in the offered "report " screen. When this happened again I worked out that the camera was somehow involved so now I just go in after using the camera and kill / stop the gallery if it's started running. Haven't found it since the new OS update last month.
  8. #28
    krk
    krk is offline
    Quote Originally Posted by Dorian View Post
    So, sounds like there were enough reports to catch the eye off the OS bug team and they sorted it in the current release. I'm amazed they don't patch earlier versions, Microsoft (sorry to swear) do every month!
  9. #29
    Somewhere on Kamino
    83 times
    Ah ok then it's working fine?
  10. #30
    197 times
    FurryVarmint
    When you say dropping, do you mean from 100% to 15%? Or what?
  1. Nexus One Accessories
    By TMODroids User in forum Nexus One
    Last Post: 01-22-2011, 03:00 PM
  2. Good news for iPod/iPhone/iPad Users
    Last Post: 01-03-2011, 09:25 PM
  3. Nexus S Rooted in Less than a Day!
    Last Post: 12-28-2010, 04:28 PM
android mediaserver process battery nexus s
battery drain media server toshiba thrive
mediaserver battery drain on nexus s
mediaserver nexus s
nexus s forums
nexus s gallery battery drain#gsc.tab
nexus s media server
nexus s media server battery drain
nexus s media server process
nexus s mediaserver
nexus s mediaserver battery
nexus s naked
nexus user forum
what is media server nexus s
what is mediaserver on nexus s
