Samsung TV audio output
This is a discussion on Samsung TV audio output within the Off-Topic Forum forums, part of the Off-Topic Area category; So we have an 800 watt receiver connected to our HDTV which works perfectly fine while watching TV. When we connect our Xbox via component ...
Thread: Samsung TV audio output
    Member Zach's Avatar
    So we have an 800 watt receiver connected to our HDTV which works perfectly fine while watching TV. When we connect our Xbox via component and laptop via HDMI the sound does not work anymore. It worked about a week ago but all of a sudden the audio just comes out of the TV now. could it be something wrong with the tv?
    62 times
    Have you re-selected the proper inputs? Often, some receivers have a 'preferred' connection, and if it detects a connection/device on it, it defaults to that input, requiring a manual override to select your desired input.
glaxcy overide audio output
note2 tv output
