Samsung GS2 mobile network connection problems
This is a discussion on Samsung GS2 mobile network connection problems within the Rescue Squad General forums, part of the Android Rescue Squad Support Forum category; Hi, thanks for any help. I just bought a samsung gs2 for my first smart phone, so basically i have no idea what im doing ...
Thread: Samsung GS2 mobile network connection problems
    Android Lurker candybarzz's Avatar
    May 2013
    I just bought a samsung gs2 for my first smart phone, so basically i have no idea what im doing most of the time.
    My battery was draining constantly and I had to recharge 2 times a day and it would die overnight when i wasnt doing anything. so i found a website that suggested the app juice defender. it worked great at first and the battery was draining a lot less quickly. then a couple of days later, i noticed i could not get on the internet or use any apps that did without being connected to wifi.
    i tried a few things: toggling airplane on and off --didnt seem to do anything
    uninstalled juice defender--nothing
    factory reset- nothing
    when i go to my status it shows mobile network disconnected
    when i go to mobile network use packet date is checked; network operators shows a default setup which cannot be clicked
    not sure what else you would need to know or i would need to do as i am new to this. thank you for any help
    May 2013
    nvm i figured it out...well actually i emailed company for support and i got a reply that i was suspended. you cant listen to the radio or pretty much do anything besides go on the web w/o being in violation of the tos...so they had suspended me with no warming or notice after the fact. so i guess i have to look at other service providers b/c i like to listen to a radio station at work that i cant get any other way.
  1. Replies: 5
    Last Post: 08-23-2013, 03:11 PM
  2. Replies: 2
    Last Post: 01-11-2013, 07:43 PM
  3. Lost Mobile Network Connection
    By jgreenmusic in forum LG Optimus One
    Last Post: 04-25-2012, 09:34 AM
  4. Network connection error in samsung galaxy s II
    By balaji.r06 in forum Samsung Galaxy S2
    Last Post: 07-11-2011, 09:34 AM
  5. Replies: 2
    Last Post: 03-10-2010, 04:18 AM
data mobile network on samsung gs2
getting no connection for samsung gs2
no network operators gs2
samsung gs2 connection error
samsung gs2 mobile data problems
