Swype Does Not Work
This is a discussion on Swype Does Not Work within the Rescue Squad General forums, part of the Android Rescue Squad Support Forum category; Hello, I have been a Droid user for close to 6 years. I currently have the Razr M. I was having a lot of issues, ...
Thread: Swype Does Not Work
    Android Lurker erscmmaine's Avatar
    Jul 2013
    Swype Does Not Work
    Hello, I have been a Droid user for close to 6 years. I currently have the Razr M. I was having a lot of issues, and had to have it reset today. Now I can't find a lot of my items that I usually use and came to this site for help. The first thing I need help with is Swype. I've gone into settings-Language and Imput and made sure that Swype is checked, but still won't work.
    Administrator smalltowngirl13's Avatar
    Kansas
    67 times
    smalltownlife13
    Hello and welcome to the forum!
    Have you set it as your default keyboard? This can be done in system settings / language and input as well...if not, you might try to clear cache / data of the Swype app (system settings / app manager / all / swype) and then force stop it (or reboot or both ) and then give the keyboard another try...good luck!
    The beatings will continue until moral improves...my new motto for work!
    Droid X Specific Site: www.droidxforums.com
    Jul 2013
    I've done that, it still doesn't work! I know you can hold down in the text field and usually "input method" comes up and you can set it that way too, but I'm not getting that option. I'm really frustrated that I'm having to re-install everything because stupid Google crashed on my phone. This is the one thing that I'm really getting angry about. I already spent two hours at Verizon this morning, don't really want to go back! Thanks for trying to help.
    Jul 2013
    Quote Originally Posted by smalltowngirl13 View Post
    Just figured out what you meant about setting it as default keyboard. I kept going into the settings and everything was set right, but I was missing that part - thanks!
  1. Replies: 0
    Last Post: 08-22-2011, 01:29 PM
  2. swype
    By rosario04 in forum Motorola i1
    Last Post: 06-13-2011, 04:26 PM
  3. Swype doesn't work with 2.2
    By The Law in forum Nexus One
    Last Post: 09-14-2010, 08:21 AM
  4. Swype doesn't work, even after reinstall
    By sglow in forum Nexus One
    Last Post: 07-08-2010, 08:58 PM
android swype wont come up
my swype is checked but not highlighted
my swype won't work
swype doesn't work
swype doesnt work .org .com try again
swype keyboard wont work
swype won't work
swype won't work on my phone
swype won't work
swype won't work on kindle fire
swype wont work
why doesnt swype work
why wont my swype keyboard work
why wont my swype work
why wont swype work
