Problem with Update to Android 2.3 N1 (Status 7)
This is a discussion on Problem with Update to Android 2.3 N1 (Status 7) within the Rescue Squad General forums, part of the Android Rescue Squad Support Forum category; Hi ... I have a problem with the Nexus One update to android 2.3 I have 4 GB card after format FAT 32 the package ...
Thread: Problem with Update to Android 2.3 N1 (Status 7)
    Android Lurker PrzemoZ's Avatar
    Nov 2013
    Hi ...
    I have 4 GB card after format FAT 32 the package named update.zip, try android update CWM v3.0.1.4 and it gives me an error
    Error in / sdcard / update.zip
    (status 7).
    The bootloader is unlocked
    NexusOne PVT SHIP S-ON
    HBOOT-0.35.0017
    What am I doing wrong?
    I read something about the method Passimg. I do not know how I do and I do not have any files to it ...
    Please help ...
    519 times
    Hi there and welcome to the forum!
    I'm not a technician and so I'm not in a position to give you some help, you need to be patient and hang on for a bit until we can locate someone familiar with a Nexus One - OK?
    Nov 2013
    Hi
    I think I'm sure someone will respond. I need to focus, and certainly can handle it. I am going to work in the evening and then I will after trying something. Sorry for my english. I come from Polish and I'm using google translator.
    Best Regards!
    Nov 2013
    Solved I have uploaded the full rom FRG83 and started the installation. Then as if that was not enough. After installation, the phone started to boot loop but Wipe reset / data factory, it helped. Topic to close .... Regards
  1. Replies: 0
    Last Post: 11-02-2011, 02:21 PM
  2. Replies: 0
    Last Post: 07-08-2011, 12:22 PM
  3. Replies: 5
    Last Post: 03-12-2011, 01:02 AM
  4. Replies: 0
    Last Post: 01-03-2011, 10:50 AM
error in /sdcard/update.zip status 7
