Can someone help?
This is a discussion on Can someone help? within the Rescue Squad General forums, part of the Android Rescue Squad Support Forum category; I would really like to root my phone.....My phone is a Optimus S running 2.2.2 Baseband: LS670MVD_60401001 I have downloaded: Gingersnap....I followed that and now ...
Results 1 to 10 of 10
Thread: Can someone help?
    Android Lurker michaelegoe's Avatar
    Can someone help?
    I have downloaded:
    Gingersnap....I followed that and now have Superuser on my phone.
    I have also got Clockwork recovery2.2.2 and the flash image that goes with it.
    and RebornRom.
    I have tried to make sense of the directions to install but I am just not getting it.....and if I brick this phone I will be killed by the wife.....LOL
    Can someone explain it so 2 year old would understand it.....I need a step by step lamens term explanation of how to do it and if there is anything else I need to have to be successful.
    Thanks
    MIke
    Rescue Squad fish1552's Avatar
    Savannah area of Coastal Georgia
    7 times
    fish1552
    Without knowing the exact guide you are using, it is hard to break it down along those steps. But generally, it goes like this:
    If you have Clockwork installed, that usually has the rooted kernel build into things. So you may already have it. Download and install an app called Android Terminal Emulator from the market, and when it finishes, open it and type "su" then hit return. If it lets you approve access in Super User, then you have root. If not, you still need to finish something.
    Provide the link you are using so we can break it down further, because without knowing much about the phone, I'm not sure if you used sfb files, adb or something else to get recovery or where you may be at in the process. Also, please list every step you've done successfully.
    i have only downloader the above mentioned to my computer....i have used gingersnap to gain superuser and that is it.....does that help??
    Sent from my LS670 using Tapatalk
    197 times
    FurryVarmint
    If you have SuperUser access then you are rooted.
    DO NOT WRITE IN THIS SPACE
    Somewhere on Kamino
    83 times
    You have it and can verify by downloading root checker from the market.
    El Paso, TX
    59 times
    _B0BB0_
    Yup after root you need to flash clockwork. What instructions did you use?
    all i have done is downloaded clockwork and flash image to my computer.....i do not understand how to flash it....do i need to get something lik titanium backup.....which comes first clockwork or rebornrom?
    Somewhere on Kamino
    83 times
    Quote Originally Posted by michaelegoe View Post
    I have downloaded:
    and reborn rom
    If you have superuser on your phone you rooted your phone. This is what makes it difficult to try and help when you then say you only downloaded everything to your computer. Flashing a rom is the process of putting a custom rom like the reborn rom onto your phone. It replaces the stock rom that comes with your device.
    El Paso, TX
    59 times
    _B0BB0_
    How the instructions say to install recovery? You probably need to use adb.
    197 times
    FurryVarmint
    Do you have the newer version or the older version of the hardware/software?
download gingersnap root utility
gingersnap android
gingersnap download android
gingersnap root
gingersnap root download
gingersnap root utility download
gingersnap root utility how long
how long does gingersnap root take
how long does gingersnap root utility take
how long does gingersnap take
ls670mvd
ls670mvd 60401001
ls670mvd root
root ls670mvd
