Signal strength
This is a discussion on Signal strength within the Rescue Squad General forums, part of the Android Rescue Squad Support Forum category; Have you accepted any updates since you've had the phone? How long have you had the phone? Finally, what version of Android are you on?...
Results 21 to 30 of 40
Thread: Signal strength
  1. #21
    197 times
    FurryVarmint
    DO NOT WRITE IN THIS SPACE
  2. #22
    Columbia, Misery (Missouri)
    8 times
    I've accepted a few app updates, but nothing having to do with the phone, which I'm going on my 4th month of having. And it came with
    Froyo 2.2. Thanks
    Sent from my LG-P509 using Android.net
  3. #23
    197 times
    FurryVarmint
    Okay. I don't know if that rules out the original rooting method or not. I'll have to do some more research.
  4. #24
    Somewhere on Kamino
    83 times
    It should be fine. Updating apps shouldn't affect the root.
  5. #25
    197 times
    FurryVarmint
    I was referring to the phone being 4 months old -- if the OS was updated from original before he got it...
  6. #26
    Somewhere on Kamino
    83 times
    I checked into it. They have not upgraded the Optimus T.
  7. #27
    197 times
    FurryVarmint
    Here are the most updated rooting instructions I can find -- but they require a PC.
    Android Forums - View Single Post - [How-To] Root LG Optimus T
  8. #28
    8 times
    Thank-you both of you for a piece of your valuable time. I kind of understand that link you sent me to; I also read somewhere if you're not sure of yourself, don't do it. Kind of like skydiving, or anything in life for that matter. And I've read horror stories about newbies, just like me, bricking their phones. I guess they use another phone or pc to get back in a forum for help.
    Maybe this phone ain't worth the hassle, and I wouldn't know how to take advantage of it being rooted anyway. I don't have the money for a new phone right now if I screw this one up. It's a good phone the way it is, i'm going to leave it alone. Thanx again. I'll be back.
  9. #29
    197 times
    FurryVarmint
    Okay. You could try z4root, but I doubt it'd work. Another option is SuperOneClick -- but again, that requires a PC.
    Basically what that link is telling you to do is to install the SDK (Software Deveopers/Development Kit) available free from Google on a PC, then you run ADB (Android Debugging Bridge) and type those commands into the PC (once you have the requisite files) to copy the software to the phone, granting you root access.
    If you have Linux then you just need to open the terminal. But you still need those files.
    If you have any doubts, though, you probably shouldn't try it untill you know for sure what's happening.
  10. #30
    8 times
    You make me understand a little bit more, but I'm still not comfortable with it. (I can borrow a laptop). And out of curiosity I tried pulling up z4root a while back and the page couldn't be found. And then there's titanium back-up and restore and bloat freeze and stuff your supposed to do before or during root...I'll attempt rooting a different time and a different phone. I need you guys to know how much I appreciate what you've done for me...
  1. No signal when 3G enabled
    By Kheemskerk in forum Nexus One
    Last Post: 06-14-2011, 12:47 AM
  2. Signal loss when sending a text.
    By Uptheirons726 in forum HTC G2
    Last Post: 05-29-2011, 02:28 AM
-108 dbm 32 asu
-67 dbm 25 asu signal strength
-97 dbm 8 asu
24 asu cell phone signal
95dbm 45 asu
android kernel signal strength
booster dbm asu signal
cell phone signal strength dbm asu
dbm asu
dbm asu signal strength
my phone signal is -113db and 0asu
signal strength asu
signal strenth -107dbm 8asu
what dbm and asu should i get
what does signal strength -80 dbm 60 asu mean
