Samsung Galaxy 4G SMS Notification Won't Go Away
This is a discussion on Samsung Galaxy 4G SMS Notification Won't Go Away within the Rescue Squad General forums, part of the Android Rescue Squad Support Forum category; Hi- My Galaxy 4G has the sms notification hung up and won't go away. I was using google voice as my voicemail provider and it ...
Results 1 to 8 of 8
Thread: Samsung Galaxy 4G SMS Notification Won't Go Away
    Android Lurker 3forty3's Avatar
    Jan 2012
    Question Samsung Galaxy 4G SMS Notification Won't Go Away
    Hi-
    My Galaxy 4G has the sms notification hung up and won't go away. I was using google voice as my voicemail provider and it sent a text notification of an voicemail. Now it wont go away but the message isnt in the inbox. If I swipe down to try to clear it it comes back instantly, if I click on it, it open a new text message creation screen.
    I know others have had this problem, but haven't been able to search a fix.
    Any ideas?
    And yes I've soft booted a dozen times, pulled the battery a half dozen uninstalled google voice and changed my google voice account settings to no longer send the text notifications, plus generated another voicemail before uninstalling it, had it send a text notification, deleted it and it still didnt fix it.
    343
    Jan 2012
    Bump.
    Somewhere on Kamino
    67 times
    Did your phone at some point get a software update.
    Jan 2012
    Not that I am aware of. The T-mobile mod in their forum hasn't mentioned anything like that.
    Somewhere on Kamino
    67 times
    Did you install an sms app? Try using handcent.
    Android Lurker richardblast's Avatar
    Apr 2012
    I've had this problem on my Galaxy S II as well and it's super annoying! But finally, I find the way to fix it:
    Download an app called "Reset Unread Sms" by Kamosoft from the Play Store and run it. Problem solved!
    Awww, yeah! Praise the Lord!
    Android Lurker jyearout's Avatar
    Jun 2012
    This is the solution
    Quote Originally Posted by richardblast View Post
    I kept getting unread text notifications but could not find any. What I believe was happening is that I would delete a text thread and shortly upon deleting a new text would come in related to that thread, but get caught in the delete process. Then I would have an "unread" text that I could not read thus the recurring notification even upon clearing from notification bar it would return every time I would open a new, or create a, text. This app identified the unread apps (which allowed me incidentally to see where they were from and to read them. This solved a significant annoyance for me. Thanks for the suggestion. But I do find it strange that I could not find these texts anywhere other than limbo.
    Android Lurker Fuelgasscrubber's Avatar
    Jun 2012
    Fixed!!
    "Reset Unread Sms" saved the day!! Thank you so much!! Hours I spent over days trying to fix this thing and I was willing to do almost anything!! This was simple, free and... All I can say is Thankyou, thankyou, thankyou!!. I registered with this site just to say thanks!! So THANKYOU!!
  1. No Vibrate Notification in Galaxy S2 (T-Mobile)
    By russgerber in forum Unlisted Android Phones
    Last Post: 04-17-2012, 02:44 AM
  2. Reg: Notification Bar in Samsung Galaxy S2
    By mslprabhu in forum Samsung Galaxy S2
    Last Post: 12-18-2011, 09:44 PM
  3. Voice Mail notification/Text message notification
    By medicsunny0607 in forum LG Ally
    Last Post: 08-15-2011, 05:13 PM
  4. Replies: 1
    Last Post: 04-20-2011, 09:16 PM
android new message notification won't go away
galaxy s3 text notification won't go away
how do i take the messaging notification badge off of my galaxy s2
message notification on galaxy s3 is not go away
samsung galaxy 3 sms wont delete
samsung galaxy email number won't go away
samsung galaxy message notification won't go away
samsung galaxy s2 message notification won't go away
samsung galaxy s2 sms notification won't go away
samsung galaxy s2 text message notification won't go away
samsung galaxy s2message notification sort go away
samsung galaxy s3 message notification won't go away
samsung galaxy s3 sms notification won't go away
why wont a text notification go from my samsung s3
